Hi all,
-I have some problems with my Beomedia 1, it is connected to a BV7-32, and it have been working excellent since 2005. However, I moved my setup and reconnected my Beomedia 1 and the BV7-32. Now when i press PC on beo4, the menu appears (Music, radio, photo, web) but nothing else happens, its like totally frozen and the red dot appears in the lower right corner (standby). I have tried all sorts of resets, on beomedia 1, unplugged the BV7 etc, but it still is the same. I can access Beomedia 1 from a laptop, so the network seems fine. The difference from my earlier setup is that I previously had BL3 and a settop box connected (I bought a BV8-40 which now is connected to beomaster/sound 5, BL3 and use the settop box). Now it is only the BV7-32, the BV7-1 and Beomedia 1.
I have the Beomedia1 on the AV4 connection, if that matters, I tried AV1 before.
I would really appreciate any hints, or suggestions on how to get passed the "red dot".. (I have tried to get to the system menu (<red><9><0><0> etc.., but nothing happens..)
/Jonas
