Can I connect Beolink pc2 to my PC Windows XP and listening musical files and internet radio trough Beolab 4000 without use Beosound?
Beolink pc2 and beolab 4000
Hi, yes, you can use BeoPort / BeoLink PC2 as an audio master (set it up to option 2), as long as you don't have any BeoSound or BeoVision in your setup.
You'll press CD to access the PC CD, NMUSIC for audio files & NRADIO for internet radio.
Thanks for your reply. I have an other question: Can i link Beolink pc2 to Beosound 3000 for listening net music?
Sure you can, in that case, BS3000 will be the audio master (A.OPTION 2) and BeoPort will be in option 6, if they are in 2 different rooms. If in the same room, BeoPort connected to BS3000 via Masterlink will be in option 0 and you can get rid of the extra IR eye.🙂
Do you advise me to add a beomedia 1 even if I do not have a B & O TV?
- Can I use the Beolink PC2 / Beoport as a standalone unit without Masterlink?
- How does it behave in a Masterlinksetup with a Beosound 5 and Beosound 3000: When I want to listen to N.Music on a PC/Mac, too; will it work?
