XML File for Samsung UE46B8090
I am locking for a XML for this LED-TV. I have a Beo5 Remote.
Best regards, Bianca
A Very Warm Welcome to Beoworld..
I do not have an XML file for this model Samsung LED TV, but one could be made if you could find the IR codes.
There are really three main ways of getting these IR codes:-
  1. Capture them from the original remote (Best way)
  2. Find Pronto HEX codes on the web at sites like www.remotecentral.com
  3. Some manufacturers publish the codes on their web site
So, the first task is to find the IR codes associated with this Samsung model.
I have found a link for thie ir-codes:
Bianca,
The link does not appear to cover all the common commands, but I have created an XML file with some of them which you can download
Hi!
It doesnt work :-(
lazarus1 wrote:
It doesnt work
Well Clearly the Pronto IR codes you found were not compatible with your Samsung unit.
You best approach is to capture the IR codes from the Original remote control, then you will know for certain that it will work.
Dear Lazarus1,
There is an XML-file for a Samsung LCD in my account, try this one. It works fine with my new Samsung LCD (direct with BEO5 and -6).
Dave
Hey!
Thanks. It works fine :-)
Is it possible to use the hard-buttoms with the colors and the cursor?
Thanks!
This XML file is one I have previously produced which has the hardkeys assigned including the colour buttons.
Open the file with a text editor such as Windows Notepad and you can see for yourself.
The hardkeys doesnt work!
