Wireless adapter
Has anyone used a wireless adapter in to the USB port for transferrin music and gettin the n.radio?
I'm wondering If there's a simple plug n play option without much hassle..
MJM
I am not sure if this answers your question, but I have my Beosound 5 connected to an Airport Express.
Yes,
I use a D-Link USB Wifi adapter. Simply rip your installation CD/drivers to a pendrive, go to maintenance mode (add mouse and Keyboard where needed), in XP, install software like any other PC, then install hardware. Log in your routers code and simples!. Reboot/Exit maintenance mode and it should all work automatically.
10
With Airport Express all I had to do was connect it.
Connected it and got n. Music, etc?
Correct. I can load music on to it wirelessly using both Beoconnect on my iMac and using Beoplayer on a Windows laptop. N. Radio works. Also can stream music from it to iPad and use iPad to control the Beosound with the most recent software update. In other words, all works just as it should.
or you can use this one:
http://www.asus.com/Networks/WiFi_Networking/WL330gE/
I'm using it without any problems on my Beosound 5.
Just wondering how you connected it (what kind of cable etc) and to which port on the Beomasyer 5?
I plugged the Airport Express into an electrical outlet and the cable that came with the Airport Express plugs int the Beomaster. Did not need to buy anything other than the Airport Express.
I also have an airport express but it It not come with any cabels. What kind of cable did you use and where did you connect it in the beomaster 5?
