Hi @ all,
I thought that I inform you that you can switch your Beo5 to a Beo6 by changing the Display. I found it easy to do myself and I did it because I broke the bl.. thing again as the Beo5 has not a good standing ability. However normally the Aluminium body needs changing as well which I did but looking at it if you have some tool one could widen the slot by sanding some alu of. At least worth a try and if it does not work order the body for the Beo6.
