TiVo codes and beo6
B&O stores are hopeless and so too is my local installer.
Why????
Tivo is on the PUC list. There is a puc called "G-Tivo".
It`s also in the new Beo6 CT 6.00.
Also mentioned in the old forum years ago...
Doesn`t it work?
Stefan
Yes - pretty simple.
But what I mean is that your dealer/installer/store should know about the Tivo PUC. They just have to look into the config tool.
That`s what I have done....
And there should be a PUC for the Tivo if It`s in the Beo6 CT list.
You will find more information on this site ( If the PUC is not working you can also use a Lintronic box):
/forum/general-discussion-and-questions/beocom-6000-output-voltage#post-2138089
Stefan
