The Tvix XML..
hi, Nowadays I'm really into the programming my beo5.
But the problem came out.
I can't turn on the Tvix HD CAFE by my 6500 XML FILE or PUC controll installed by my dealer.
the PUC that I have can only turn off and do other normal controls .. :(
I heard somewhere that Tvix 6600 or S1 's  remote signal is similar to my HD CAFE's
Is there any way I can get the 6600 or S1 's  XML file on the web?
Thank you all :)
You can download CT 5.12 where the next files are embedded:
TViX_STB_HdN1.xml
TViX_STB_M6500A_V02,00b.xml
TViX_STB_M6600_V02,00a.xml
Henk
 thank you. I'm trying to figure it out.
But this is PUC source, Is that mean that I have to get new PUC installation by my dealer?
