Sony BDP-S500 XML file?
I'm searching for a Beo 5 xml file for the Sony BDP-S500 Bluray Player.
Does anybody has a code for this guy? I've found some Pronto files in the remotecentral forum but they only seem to be complete setups that contain the Sony BDP-S500 and many other components!?
Thank you
Hi
I have the file but I can't add it here right now. I will try later.
Regards
Better send me a mail and I will reply it with the file. Don't know why I can't add it here.
Regards
Edited: I knew I was uploaded this file already, and I found the post. You can download it from here:
/forum/general-discussion-and-questions/bv11---difference-between-versions
Regards
Thanks Quim!
It works! :-)
But there are not all buttons of the BDP-S500 in the xml file!?
I'm missing "dimmer" for example ;-) Did you made it with the Lintronix Box and Software?
I know, people are never 100% satisfied 😁
TWG wrote:
Thanks Quim!
It works! :-)
I am glad it works 🙂
I am not sure where I got the codes, because I haven't the bluray player. I think I found them in the Lintronic page and I converted to an xml file. If there are some missing codes, I am sorry, but I made the xml with the codes I got.
Regards
Hi Quim,
don't take that "missing button issue" to serious; I was just joking. I'm realy happy that it works!
I'm awaiting the "magical" Lintronic Box and I'm anxious to see if I can copy all my infrared remotes at home with that box to make the Beo 5 more useful.
Regards!
