Slow internet
Hi!
I have my BM5 and BS5 connected to a BV7-40 MK4. I use wired internet with CAT 6 cables.
I have 94 mbit in to the BM5.
I think that internet is VERY slow when I surf om my tv via BM5.
Anyone else with the same problem?
Best regards
Christer
Using the same cat6 cable that was in the BM5, have you tried pluging it into a laptop and seeing what speed you get?
Off course, I get 94 mbit of 100 totaly. So internet is fast it just the BM5 that is really slow.
Well it is (they say) only a £250 PC with an ML bit bolted on, in a fancy black case! Some people are apparently afraid it might overheat when you play some video types on it. What a quality piece of kit😎
Seriously though, is your net radio streaming OK?
Enjoy your system, the BS5 is gorgeous.
