I know technically I am in the wrong forum, but this is where all the brainy types and boffins hang out!!!!
Has anyone had success writing their own PUC controllers? Have had a play around and it seems quite possible.
The PUC in Beovisions are loaded by dealers using a B&O Service Tool and can be changed at any time by a dealer from a library of PUC files produced by B&O.
Each 3rd party product supported by the PUC and in the library has an associated DEC file. This DEC file is a text file with a format unique to B&O, but in principle is quite simple.
The file defines everything including but not limited too:-
The following is a typical example of the GUIDE button for a TOPFIELD 5800
[Signal_btnGUIDE_RepeatSignal]
IRSEQUENCE=NEC
Pause1=0
Pause2=0
Carrier=38
BITLEN=546 570 0
PRESIGNALBITS=0 0
PRESIGNALHI=8995
PRESIGNALLO=2250
BITS=1
[Signal_btnGUIDE]
IRSEQUENCE=NEC
Pause1=39400
Pause2=95500
Carrier=38
BITLEN=546 570 1700
PRESIGNALBITS=0 0
PRESIGNALHI=8995
PRESIGNALLO=4480
BITS=111110110000010000100111110110001
REPEATSIGNAL=1
Comment=NEC 32bits=FB0427D8
I have written a Windows based programme which converts any PUC DEC file into a Beo5 XML file and doing the reverse would not be particularly difficult.
Producing the DEC file for a particular product in my view is not technically difficult, but time consuming without a software tool.
The issue is that only B&O dealers have the Service Tool and the special Masterlink cable which uses pins 9 & 10 to send the data to the PUC in the Beovision.
If you are a B&O dealer reading this and you know how to produce and upload the PUC, then you could produce your own DEC files to add to the B&O library and upload to your customers Beovision. This can be particularly important where you have a customer requirement for a 3rd party product to be controlled by the PUC, yet B&O do not have any plans to add that product to the PUC library. You may not get a big sale for what is a technically small requirement.
I am very interested in that subject because I would need to change the entry for the Sony HX1010 DVD recorder for my Beovision 7.
I have a Sony HX715 DVD recorder and I would like to add three commands: STOP, GUIDE and TITLE LIST.
My questions are:
1- How to extract the entry for Sony HX1010 from the TV? A special software is certainly required for this.
2- How to capture the IR commands from the Sony remote to get the numbers shown in the previous reply?
With an IR receiver that is connected to the computer and a capture software?
Is this available somewhere?
3- How to upload the new or modified PUC entry to the TV ? With some special B&O software?
Thanks in advance,
Jean
Jean,
In answer to your three questions, my answers are as follows:-
Keith,
Many thanks for the info.
So it appears that it will be a quite complicated job for just adding two buttons.
Thanks,
Jean
Jean,
Well, not particularly technically difficult, but even if you had a copy of the DEC file and updated it successfully you would still need your dealer to update you PUC with the Service Tool.
Dear Keith,
Sorry for reviving this thread two months later. I had the software and the PUC list on
my BV-7 upgraded by my dealer a few days ago and I discovered that by combining
some commands of the entries of the Sony RDR HX-1010, HX-780, and HXD 995, I could
get a reasonable control of my HX-715 DVD recorder.
Are these "DEC" files human readable and editable? I could then create my own PUC
entry using a combination of the codes from these three entries.
Thanks in advance,
Jean
I believe that my first answer in this thread fairly clearly states the situation.
The DEC files are flat text files but in a format unique to B&O and whilst they can be modified, you would need to fully understand their structure and also get the support of your dealer to be willing to download a modified version.
Keith,
I would be very interested if you could write as you proposed above a reverse XML - PUC software/function. It would be extreamly valueable to be able to create a fully functional PUC listing for the settop boxes that I am responsible for here in Norway. I have managed to get two into the normal PUC listing via B&O but this is quite an effort and it involves logistics and testing with weeks in between each "version".
Sincerely hope that you could find the time and effort to create this.
//Rolf
Keith,
I am ressuscitating this old thread for getting one information: What are the Beo4 mappings for the RDR HX1010 PUC entry? In particular:
SYSTEM MENU as shown in the JPEG image.
Thanks,
Jean
