PS3 on/off with Beo5??
I'm having Sky HD installed tomorrow , the B&o man said I will need the Scart connecting as well as the Hdmi so as to get Sky on the Link Tv . Is this a way to get the Ps3 on the Link Tv by connecting the AV Multi Out on the Ps3 to the Bv7 scart , but still have the Hdmi cable also to the 7 for HD ?
Richard
No, you can only choose one connection in PS3 menu :-(
and BV7 can not route HDMI signal to link room
hello,
I have just purchased the smartz-usb thing. but i cant get rhe ps3 to react to the ir signal from my beo5 remote.
I have it on V.AUX. is this correct??? please write instructions how to config. I have a Beovision 8.
//Kalle
You must have Sony DVD (Sony NS975V) in your STB list. Do you have that?
Yes, I have that in my list. Should I use that? I also have Playstation 3 in the list. but neither of them works.
//Kalle
Yes, not PS3. It only works with Nyko remote(
I am confused. isn´t the whole point to use the Beo5 remote against PS3???
So what you are saying is that I still need the nyko remote?
//Kalle
Beo5 can not pilot any other brand direct for now
No need for nyko if you have schmartz
