PS3 on/off with Beo5??
Hello!
I use the USB-IR dongle of the Nyko and it works fantastic with my Beo5 (PUC of BV7-40 MkIII). How am I able to switch the PS3 on/ off with the Beo5? Do I ´have to add some commands? I used the standard commands offered by the configuration tool..
Thanks for help
TS4
Unfortunately, you can't control the on/off of the PS3 with just the USB-IR dongle. The dongle requires the power from the USB in order to receive IR commands. There is, however, a recent solution by Schmartz that provides on/off control by attaching a sticker to the on/off touch-sensitive button; however, the cost is $50. My understanding is that the Schmartz device uses a different code-set than the Nyko device.
Since I am usually inserting a Blu-Ray disk anyway when I'm starting the PS3, the lack of "on" control by remote hasn't bothered me. I just wish that Sony would add an option for the PS3 to automatically power off after a period of non-use. I tend to forget to turn the PS3 off.
If i buy the Schmartz-thing, what do i get? Is it a sticker? Or an USB-dongle? And the most important question: How am i able to use the ON/Off-button with the beo5?? I have added the "V.MEM" Menus of the PS3 with the beo5-config-tool and installed the NYKO-USB-dongle and i am able to control 100-1% of the PS3, only on/off misses. Which buttons of the beo5 will control on/off when buying this schmartz-thing?
Thanks for any further detail
Regards
TS4
Ok. This sounds interesting.
Do you use the original PS3-Menus of the config tool on your Beo5? Or did you program totally new ones? At the moment i have to press v.mem on the Beo5 and have the buttons of the PS3 on the next page. Why do you (mr anders(son)) need a BM1 if you have a PS3?? I installed yellow dog Linux on the PS3 and have a complete computer on my BV7-40!!
I use a Sony DVD NS95 in PUC list and it works 99.9%.
I have done my own buttons in Beo5
I had BM1 before PS3 ;-).
The downside with PS3 is that you can not use it in linkroom if it´s connected with HDMI!
This yellow dog thing, can you explain more what it is please?
I get Ps3 in my link room , don't know if I can control it yet in the link room till I configure the Beo5 with the Nyko . Would prefer to use the Beo4 in there , my dealer is coming on Friday to flash my Bv7-40 so I can .
Richard
Richard
have you PS3 and BV7 in linkroom ?
Sorry I jumped the gun here . set-up is Bv7-40 main room + Ps3 via Hdmi , Bv6-22 in link room . They put the Bv7 Tv in last Friday and I asked if all functions on the new set ( Sky , Dvd ect. ) were available on the Bv6  , he said yes but I didn't try the Sony and it is not there . But having the Tv flashed on Thursday to put Ps3 in the box list  and they are going to put in a Rf modulator ( apparently no Modulator in the Bv7 ) so I can get Dvd2 ( sony Ps3 ) in the link room and hopefully also control it .
Richard
