When i pres the "Power off" button on my BEO 5-remote it shuts down and reset the battery.
I Have used the latest Config tool 3.57 and the firmware is 1.41e.
I am the only person who has this problem?
3.57??
where did you get that from???
3.57??
Yes I well like to no that too π
I'm working with Config Tool V3.0 and it works.
Which file did you use? The one from Keith? I didn't have the time to check his latest version, will try it this weekend.
The PS3 should only power off. What do you mean by "battery reset"?
I used the fil from WB electronics homepage.
Battery reset = The remote turns off and restart with no battery
How many different files is available?
You can download the XML file I modified
I will test the modified version from you and respond to you later.
Thank youπ
Does this Battery Reset happen every time you press Power or did it just happen once.
If you upgrade from an old firmware version the Battery level is reset.
I know the battery reset can occur when you opgrade firmware. But I can tell you that the new config tool 3.57 updates your remote with new firmware(1.42a) without battery reset.
The XML-fil I have the problem with every time I pressed Power is from WB-electronics homepage.
But rigth now I am testing af version from Keith. And it seems to work.
Not mineπ
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
