Problem with the XML-file for WB Electronics RE-BL PS3-adapter
When i pres the "Power off" button on my BEO 5-remote it shuts down and reset the battery.
I Have used the latest Config tool 3.57 and the firmware is 1.41e.
I am the only person who has this problem?
3.57??
where did you get that from???
mr_anders_son wrote:
3.57??
Yes I well like to no that too 😎
I'm working with Config Tool V3.0 and it works.
Which file did you use? The one from Keith? I didn't have the time to check his latest version, will try it this weekend.
The PS3 should only power off. What do you mean by "battery reset"?
I used the fil from WB electronics homepage.
Battery reset = The remote turns off and restart with no battery
How many different files is available?
You can download the XML file I modified
I will test the modified version from you and respond to you later.
Thank youπŸ™‚
Does this Battery Reset happen every time you press Power or did it just happen once.
If you upgrade from an old firmware version the Battery level is reset.
I know the battery reset can occur when you opgrade firmware. But I can tell you that the new config tool 3.57 updates your remote with new firmware(1.42a) without battery reset.
The XML-fil I have the problem with every time I pressed Power is from WB-electronics homepage.
But rigth now I am testing af version from Keith. And it seems to work.
Not mine😭
