Problem with self-made xml-file for Automation lift.
Hello
Can anybody help me?
First details:
Programs used: Beo5 config tool 3.59, Lintronic old version (001.004.005)  and Beo5 3rd party XML generator (version 1.1.0.1)
Beo5 firmware: 1.42a.
Hardware: 1. Beo5 with serail number >21404408.
                  2. Lintronic TT455-RT-238.
                  3. Future automation lift (but no info about type/model).
I have captured the two commands up and down with the Original remote. The Lintronic software recognize the two IR-codes as NEC format. So i have set the frequency to 38KHz in the 3rd party xml generator.
And then i drop the XML-file as usual in to the Beo5 config tool.
I now have two Buttons: "Up" and "Down" on the Remote.
When i press them, the Lift makes no reaction.  The back of the Beo5 remote shows activaty when I Press one of the buttons. (the usual two flashing red lights.)
I therefore tried to capture the signals from the "Up" and "down" on the Beo5 remote with Lintronic. And that was no problem WHY???
I was cable of sending the IR-commands from Beo5 with the Lintronic (using the "test" function in the software) back to Lift IR-receiver and then the lift reacted and made the movements WHY???
A resume of the problem: The Beo 5 is sending the 3rd party IR-command but the 3rd party IR-reciver (furture automation lift) receives no commands.
I hope you can help me. (keith Saunders)
Thank you
Regards Christian
Christian,
I understand your problem and I can confirm that the Beo5 can control the Future Automations lift product using NEC protocol without problems.
Click link to download a working XML and link for an alternative layout version.
The hard keys in these XML files are pre-assigned meaning it should be Plug-n-Play
Extract from the ZIP file to C:\ and then the files will be added to the correct directory.
Please provide feedback with your experience using these XML files.
