Problem with Digits
I have noticed that somehow my Beo5 no longer issues commands from the digits page.
The Beo5 was (when this problem was first noted) was written with config Tool 2.20 when I first started using (and configured for ) a BS5.. With Config tool 3, the problem has not gone away or been over-written
The digits are still available to be seen and touched, offer a halo and click when pressed but do not send out a command.
Anyone any ideas about what has happened and how to correct the problem? The Digits Page cannot be edited with the config Tool.
 I dont use the digits that much but do like using the CIFFER_0 button to flick between two channels. It's annoying not to know what has happened.
10%
Have you tried making a new configuration from scratch? It sounds as if something has gone wrong in your configuration. My recommendation is to find the folder where your configuration is and move it somewhere else (this also gives you a backup) and make a new configuration. Hopefully that would work.
Br,
Burnix
Best thing whould be to try the configuration inside the Beo5 Tool, to see what commands are sent after you push the digits.
regards
The digits cannot be re-assigned using the latest version (or 2.20) of the Configuration Tool. However, you can assign them to anything you want too, within a template and then add the template to your configuration within the Tool.
