Problem with 3.87
My two Beo5 drain battery dramatically! But not all the time. They are about one year old. I have reset them both and reinstalled my configuration but after a while it happened again. Could it be an error in my config file?
Whilst you could have a problem in your configuration file particularly if it includes third party products which use RAW, there is a generally known problem acknowledged by B&O with the firmware version associated with 3.87 which can drain the battery.
There is a new release which is likely to be seen before the end of this year which hopefully will resolve the issue and a few others.
Hi
Can you tell that the New version well be, v3.90 or v4.00 or !
It will be Version 4.1
