Mac adres
Hi everyone,
Where can i find the mac adres of the beo6?
Regards,
sl
Get into your router (login) and look at "attached devices."  Your MAC address will be listed there.
Thanks al lot!
Press standby and the Go button on the Beo6.
Then go to Beo6 info. There you will find the MAC address.
If it isn't listed there (0.0.0.0), then first you have to make contact with your acces point from your router.
I discovered that both buttons “info beo6” and “server ip” are invisible. By pressing on the please where the buttons should appear, the needed information is displayed. Do you know why these buttons are invisible?
Firmware version: 4.3.4
