Looking for a specific XML-file
Recently  the PUC table of both B&O TV's are upgraded with the Humax IRHD-5000C drivers. So my HD decoders can be controlled with the B&O remote.
But not with the BEO5. I don't have the right XML-file. It was not included in the last software update. Because I program the BEO5 myself, I hope that someone has the right XML-file for het Humax IRHD-5000C.
The file can be found in the map Bang & Olufsen\Beo5 Configuration Tool\ThirdParties\Sources\    and is named somthing like HUMAX_IRHD-5000C.xml
Please let me know.
Piet
Sorry Piet, there's no such file!
I found a HUMAX_IRHD-5000C.xml, but it was in Bang & Olufsen\Beo5 Configuration Tool\ThirdParties\PUC Sources\.
So it will use your PUC file. But you wrote that your TV are upgraded with the Humax IRHD-5000C drivers, so you should be able to use your Beo5 with this xml file.
Let me know if you can use the file. Then I'll send it to you.
You have mail.
Piet,
Still looking for this xml file? I can make one with 39 commands to send you to test.
I'm waiting for your answer.
Regards
Hello Quim,
nice to hear from you. Well I have got a XML file from Brian and will do tests with the file. Only not today because it is perfect weather for outside pleasure. I let you know the results.
Thanks for your offer, anyway.
Piet
