Log in CT 6.62
Why can I not login in the CT 6.62
I have the right username and password
with the CT 6.00I have no probleem but with the CT 6.62 is a problem
He say Invalid user/password combination!
I can only open if I work offline but than I have no update`s
I imagine it is the intention only dealers are able to logon, however due to a bug it was possible to logon for eveyone using older versions of the software. After version 6.00 only dealers with valid credentials are able to logon. I have the same issue and can only logon with versio 6.00. Still have a very old windows xp laptop just for this old tool. Would be nice if it was possible to use a newer version, but on the other hand, since b&o apparently does not want to supply the tool and discontinued the beo6, i am more or less considering to abandon it and buy a new beoremote1
Better wait for upcoming Samsung universal remote control which can also control Bang Olufsen. My Beo 6 new battery, but several times battery drain when not on loader.
Any news about the Samsung remote control? Can anybody provide me with a link to it? I didnot find any information about it.
Thank you
