I got my new Beo5 today, firmware is 1.40a which refuses to download Configuration Files created with Config Tool v1.30.
Anybody knows a solution to this problem?
Is there a "changelog" what's different in the new firmware and in the new config tool?
Perhaps it solves some problems (like mine) where the Beo5 refuses to get the configuration ...:-(
Does the software add support fot Beosound 5/Beomaster 5?
p.
I wonder if the PCG has been updated as well...
p.
Improvements
New B&O products added:
• DVB-HD.
• BeoVision 7 no DVD.
• Preparation for BeoSound 5.
Engine improvements, less or not visible to the user:
• Major changes in the internal architecture of the tool software.
• Serializer efficiency is improved in terms of binary size, leaving more space for e.g. logos.
• Error corrections on both tool and firmware improving support for 3-party IR.
Errors corrections:
2 A-rated errors, 23 B-rated errors, 20 C-rated errors, and 16 D-rated or not classified errors. Totally 61 errors.
Emphasised corrections:
080905 Not able to change speaker mode in N.MUSIC/N.RADIO.
085485 "Text" button missing within Text menu on DTV and VMEM source.
085763 AV-sources not available in link room.
085399 MENU not sent with link bit on bl3500 in option 4.
084134 If you change the name of the speaker modes they no longer work.
076113 Serialization error when using BC 2-MKII with BeoCenter 6 in the same zone.
082532 Error deleting delays in macro.
085293 No DVB-T for BeoVision 8.
081020 Imported configuration is not stored correctly.
082540 V.MEM separated into V and MEM.
076541 Serialization failed when a channel number is 0 or bigger than 65535
078833 Serialization error when moving /TV/ button.
