Keith Saunders wrote:
If you have the pronto codes for each of your buttons then translation is fairly easy.
Post a few of your captured pronto codes and I will convert them into a simple xml file for you to try.
Good morning Keith and thank you for your support.
I don't have pronto codes: I drop the idea of buying a pronto capture device some time ago when I figured out I still would need a "translator".
The idea behind this whole search is to be independent and not having to bother you each time I add a device or change configuration!
I checked to see what protocol Hitachi generally use and it is NEC protocol
Attached is a Generic XML file for Hitachi
I've carefully looked the link and picture you provided but I can't see a pattern or find a link between the waveform in my capture device and the xml you provided. Neither what to do with Data and User. All dark science to me!
The Phillips protocol code page on the beo5 website show details on the waveform but the NEC protocol page don't.
I wished it would be as simple as drawing the waveform with 0 and 1 in some kind of xml file but it seems it's not that easy.
Anyway. If on your side you can do something with the codes and waveform shown in my device, I would accept your proposal of xml file.
There is one device I'd like to add to my Beo6, actually the only other remote lying around. That would be just a on/off command.
Its a Yamaha processor but as far as I've tried it's not a generic Yamaha command.
Thanks again.
