Infrared volume control
Hi everybody.
I was wandering if any of you could recommend me an infrared volume control for my active speakers, so that I can use my Beo5 to turn the volume up and down?
At the moment I'm using a NanoPatch, but it has no infrared receiver, so i have to turn the volume up and down manually.
I hope that some of you have some suggestions, bellow I have attached a picture of what I'm using now.
All the best
Niels
Hi Niels,
More details would help everone help you.
What is your current set-up? what speakers are you using? are they connected to B&O? B&O do a few things that would probably help but without the full detial of what you have and what you are trying to do, we would only be guessing 🙂
Stoobie
Exeter,
Devon,
UK
Ask Revoxbeo they probably have a volume control for BEO
Regards
Hi again.
My speakers are actually not B&O, but Genelec.
My setup is very simple. I have two active speakers connected to a volume control, to were my CD and MP3-player is connected.
My question is: Do you guys know a good and reliable volume control, to where I can use my Beo5? It might be B&O or it might be some other brand.
All the best
Niels
did you ask Revoxbeo ?
