How to add album art to FLAC files
I have just added a library with FLAC formatted music files to my BM5/BS5 system. The files in-themselves play on the BM5/BS5 without issues, however the album art (jpg in same library) is not displayed and is replaced by the defualt B&O album picture.
Normally I am able to add album art manually via my Beoport/BeoPlayer connected PC and the drag and drop principle, but as the files are in FLAC and BeoPlayer does not support this format the Album is not detected and therefore it is impossible to add the album art.
Any ideas ?
//Rolf
try mp3tag; its free and easy to use
www.mp3tag.de
Try mediamonkey
www.mp3tag.de
Your right,
This is the best free program🤒
Very easy to use.
I am using an iMac. All of my music was ripped from CDs in FLAC by the dealer and installed on a portable hard drive. The music was then dragged from the hard drive to Beoconnect. Most of the music has cover art but a few CDs do not.
How do  use one of the programs mentioned here to fix that? Does it install on the iMac? The Beomaster?
If on the iMac how does that affect the music on the Beomaster?
Thanks!
