help whit XML file (HYUNDAI, SAT RECEIVER, HSS820)
got those code from Lintronic and i wonder if you can make it whit this( XML files to control Beo 5.)??
Does anyone have any ide if i can do that??
Regards Claudiú
LinTronic CommandFunction
link0010140000000000000
link0010010000000000001
link0010020000000000002
link0010060000000000003
link0010040000000000004
link0010050000000000005
link0010070000000000006
link0010080000000000007
link0010100000000000008
link0010110000000000009
link001026000000000000AUDIO
link001019000000000000CH.LIST
link001022000000000000CHANNEL.DOWN
link001021000000000000CHANNEL.UP
link001030000000000000DECODE
link001018000000000000ENTER
link001017000000000000EXIT
link001024000000000000GUIDE
link001031000000000000HDD.DEL_SKIP
link001009000000000000HDD.LIST
link001032000000000000HDD.MENU
link001028000000000000HDD.RECORD
link001025000000000000INFO
link001016000000000000MENU
link001003000000000000MUTE
link001000000000000000POWER
link001013000000000000PREVIOUS
link001029000000000000SLEEP
link001012000000000000TV_RADIO
link001015000000000000TV_SAT
link001020000000000000VOLUME.DOWN
link001023000000000000VOLUME.UP
Happy to see you've finally fixed THIS problem you had some days ago...
...by the way, don't mention it ! 😕
did you solve this problem? got the same problem, but other devices ;)
no i did not fix my problem, and i dont have any ide if it can be done, does anyone know?
thank you very much
claudiu
Claudiu,
All Hyundai STB's use standard NEC protocol IR codes and so an XML file can be made for this product without much trouble. The Lintronic codes you listed start 713 meaning NEC.
Send me a PM as a reminder, but in the next week I will put one together for you to test.
Thank you very much that you will help me to make this xml file for my hyundai setup box.
Regards Claudiu
I have sent you a PM with a download link on Friday
