help whit XML file (HYUNDAI, SAT RECEIVER, HSS820)
Happy to see you've finally fixed THIS problem you had some days ago...
...by the way, don't mention it ! 😕
no i did not fix my problem, and i dont have any ide if it can be done, does anyone know?
thank you very much
claudiu
Claudiu,
All Hyundai STB's use standard NEC protocol IR codes and so an XML file can be made for this product without much trouble. The Lintronic codes you listed start 713 meaning NEC.
Send me a PM as a reminder, but in the next week I will put one together for you to test.
Thank you very much that you will help me to make this xml file for my hyundai setup box.
Regards Claudiu
