Help - Beosound5 not working
I have Beosound 5 system - it has been working fine including applying the latest software update. However last night I noticed thatit would not switch off. So I had a power reset  but all I see on the head unit is the B&O sign with the red light flashing. I have tried to get sound but no luck. Also I have tried Beoconnect but cannot connect. I have done a power reset a few times but no chnage? Any suggestions?
Thanks,
Arvind
Your beosound 5 has lost its handshake with the BM5
Reboot the BM5 manually and see what happens
B
I have reset the power to the Beomaster 5 (server ) a few times but still have the same problem - I assume this is same way of rebooting if not then how do I do this?
Thanks,
Arvind
Disconnect the BM5 from mains for SEVERAL minutes
- in the meantime check all connections between BM5 <> BS5 and the external conections as well
- restore power, let the system boot and check if everything is OK
- if not, reboot again and select "recovery" at the boot screen
- and let the system recover (you'll lose your favorites/playlists and have to reconfig the system again)
- after recovery trigger a manual SW-Update
- if you don't get a boot screen - contact dealer / service
unplug everything en reboot the BS5/BM5. see what happens than
(naturally don't unplug the mains..............)
NO!   UNPLUGGING THE MAINS (FOR SOME MINUTES) WILL ALLOW A "COLD" START!
Your right first unplug everything, then replug only the mains and restart
hello  for this problem reboot your beomaster 5 on this BS 5  display  it s write recovery before plug a clavier on  usb  on BM5   and choose recovery  with fleche   up down  and ok   choose language  and ok   the beomaster 5  works during few minutes  do not touch  him  the time depend  internet connection  .when bm 5 stop  .  Go to setting and  download  the new version of program  lets him  works  during  15 mn or  plus  depend internet connectionn?  do not affraid  your music collection  is always in the bm 5  lets bm 5 works    apologize  for my english   Pascal Reunion Island s  i do that  it s ok for me
Thanks for all suggestions tried the power reset and worked this time! Maybe I should wait a few minutes before reseting the power.
Thanks again
Arvind
