export a Itunes playlist to BS5 Encore
does anyone know whether it its possible to export itunes playlists to BS5 Encore. I have converted my Itunes playlists to .m3u format which is recognized by twonky media server they are, however, not showing up on the BS5 Encore !
thanks
Would be great to be able to do this than spend hours trying to create playlists on the  system itself.
Yes doing it on the Encore itself is a rather tiresome process - and as far as I know you cannot remane the playlists from "RED" to eg. chrismas music. It would be great with a piece of B&O software where you can manipulate your music library on your computer rather than on the Encore.
