error during serialization
When trying to download my config file I found the following message:
"Checking buttons ...
ERROR: [537] "ZONES\WOONKAMER\SCENE\SCENE-1" hardKey  Unknown softkey"
Included the advice not to use this configuration.
Is there someone who can explain this error, because I'm a novice in programmamming the Beo5 and of course how to solve that error!
Thanks in advance,
Pim
Pim,
Its a software bug in the Configuration software, it is trying to assign a non existant softkey to a hardkey.
To solve the problem search the "Configuration.xml" file for the following string and remove the whole line :-
Thanks for the very simple solution ... I hope this bug will be resolved in the 3.0.0.2 version.
Wait and see,
Pim
