Does the configuration tool work with windows 10?
For configuring my beo5 I have a 32 bits system running windows 7.
Does someone know I it still work if I upgrade the 32 bit system to windows 10?
Thanks,
Piet
Hi, I have window 10 and it works perfect. I have config tool 6.62. Maybe earlier software will not work. But mine is working perfekt. Tried it yesterday.
/Martin
Thanks Martin for the response.
The version I use is also 6.62. My concern is the USB driver for the BEO5. This driver is only available for 32 bits systems.
So for that  I have an older system here with is 32 bits only. Are you sure that the USB driver for the BEO5 will work with WIN10?
Thanks in advance.
Piet
