Dear keith.
Is there any updated information about DCX 3200-m?
Thank you.
jack001
Dear keith.
Thank you.
jack001
I have seen the same forum entry as you about the DCT 6200 using the same IR codes, however I cannot convert a ccf file.
Hi Keith,
I'm not trying to make extra work for you but if you download and install
Dear Keith.
I got lintronic box finally!! (I bought 20% d/c year end sale!!)
I was copied my comcast box and other non b&o stuff.
But I still need your help.
Could you let me know how can I put on the channel menu in the comcast xml file? (channel logo display fuction)
I tried just copied number code in the property menu of CTtool (For example, channel 812) I copied following codes and added channel logo 8 -> 119c 1178 0249...., 1 -> 119c 117b 0247...., 2 -> 119d 1178 0249...
But it didn't work I think these IR signal can't reconize at the same time.
I uploaded comcast xml file at the BEO5 resource and information center. (
For some reason your upload did not work. Can you please attach the file to this post or e-mail it to me me at keith@beoworld.org
I sent xml file to your e-mail.
Thank you.
Dear Keith.
Did you check my dcx3200 xml file?
Please advice.
Thank you.
Attached is an xml file that I created for my motorola dvr... I created it for my old one (don't recall the model number), but it works with my current one dcx3400. Maybe this will work with your dcx3200.
I always intended to upload this to Keith's Beo5 site, but thought there was an error or two with it. However, I just used it successfully with my brand new Beo6 so either I fixed the errors (and don't recall), or the newer config tool isn't as picky as the old one(s).
Stan
Be careful with this file. There may still be issues with it. It seems to work with simple configurations, but a couple times I've hit a "System.SystemException: Setup node cannot be found ... " error as I start building more complex commands (like building channel macros).
The only way I have found to "fix" this error is to go back valid configuration - periodically copy your configure folder to safe place so you do not lose much work. Deleting whatever I added between when it worked, and when it doesn't work doesn't seem to fix this issue.
Stan
