Contorl comcast dcx 3200-m
Hi everyone!
Can anyone control Comcast Motorola cable box dcx3200-m by Beo 5/6?
Couldn't find any information so far.
If anyone has XML file for DCX3200, it would be appriciate.
I almost done my beo 6 configuration by myself except comcast box.
Thanks.
Whilst I don't have an XML file for the Motorola DCX3200, I did some research on the web and found some Pronto HEX codes which I have converted and made a test XML file. The XML file only has three commands EXIT, GUIDE and ENTER, but if they work on your box I am sure we can find some more.
You can down load the file for test
Thank you for your kindness reply Keith. I appriciate that.
Let you know after I try.
Jack.
Dear Keith.
After I saved DCX3200 XML file in my PC and configuration S/W show up name as "Product" then I added.
However, nothing come up in "EDIT" menu and couldn't made physical connection in "choose product" menu.
Did I something wrong?
Please advice.
Thank you.
The XML file needs to be in the sub-directory "Thirdparties" and if you extract the XML file from the ZIP file to C:\ it will automatically be placed into the correct B&O Configuration Directory.
Once the XML file is in the correct directory go to the PRODUCT section and click the TAB called OTHER and you should see it. Now just drag-n-drop it from the list on the left to your configuration. Note, you must have at least one B&O product in your configuration, even if you don't have or use that product.
Thank you for your kindness advice.
I was wrong. I extract XML files in the "My document" folder, not C://.
I can see come up "Motorola DCX3200 Test" with three button "ENTER",GUIDE", "EXIT"
Let you know it works or not later I'm in the office.
Thank you so much Keith.
Dear Keith.
It works!!! GUIDE, ENTER, EXIT buttons are work correctly. Great job!!!
I am truly looking forward to complete file like channel etc....
Thank you!!
To produce the XML file, I found a forum posting with Hex Pronto codes which I converted for you. Other than the three comands you have tested, the only other pronto codes were the digits 0-9.
Unless you can find more Pronto codes on the web somewhere, the only way to progress this is to get the original remote and capture the codes.
Dear Keith.
I have question.
I heard that DCX3200 pronto code works with old DCT 6200.
Than I founded ccf files from 'remotecentral' website.
Is it possible to make ccf file to xml file?
(Sorry for my poor knowledge.)
I can give you ccf file for DCT 6200 (I was downloaded form 'remotecentral" web site.)
Please advice.
Thank you.
I have seen the same forum entry as you about the DCT 6200 using the same IR codes, however I cannot convert a ccf file.
I can only convert Pronto HEX files which are in the form of
0000 006A 0000 0002 0000 00B0 0000 0016 0000 0016 0000 0017 0000 0042 0000 0042 0000 0016 0000 0016 0000 0017 0000 0042 0000 0016 0000 0016 0000 0042 0000 0016 0000 0042 0000 0042 0000 0042 0000 0042 0000 0042 0000 0042 0000 0016 0000 0016 0000 0016 0000 0017 0000 0042 0000 0016 0000 0016 0000 0017 0000 0042 0000 0042 0000 0042 0000 0042 0000 0016 0000 05D4 0000 0058 0000 0E50
