Contorl comcast dcx 3200-m
Dear keith.
Is there any updated information about DCX 3200-m?
Thank you.
jack001
Keith Saunders wrote:
I have seen the same forum entry as you about the DCT 6200 using the same IR codes, however I cannot convert a ccf file.
 Hi Keith,
I'm not trying to make extra work for you but if you download and install
Exeter,
Devon,
UK
Dear Keith.
I got lintronic box finally!! (I bought 20% d/c year end sale!!)
I was copied my comcast box and other non b&o stuff.
But I still need your help.
Could you let me know how can I put on the channel menu in the comcast xml file? (channel logo display fuction)
I tried just copied number code in the property menu of CTtool (For example, channel 812) I copied following codes and added channel logo 8  -> 119c 1178 0249...., 1 -> 119c 117b 0247...., 2 -> 119d 1178 0249...
But it didn't work I think these IR signal can't reconize at the same time.
I uploaded comcast xml file at the BEO5 resource and information center. (
For some reason your upload did not work. Can you please attach the file to this post or e-mail it to me me at keith@beoworld.org
I sent xml file to your e-mail.
Thank you.
Dear Keith.
Did you check my dcx3200 xml file?
Please advice.
Thank you.
Attached is an xml file that I created for my motorola dvr...  I created it for my old one (don't recall the model number), but it works with my current one dcx3400.  Maybe this will work with your dcx3200.
I always intended to upload this to Keith's Beo5 site, but thought there was an error or two with it.  However, I just used it successfully with my brand new Beo6 so either I fixed the errors (and don't recall), or the newer config tool isn't as picky as the old one(s).
Stan
Dear Stan
Thank you so much. I appreciate.
I will try it and let you know.
Jack.
Be careful with this file.  There may still be issues with it.  It seems to work with simple configurations, but a couple times I've hit a "System.SystemException:  Setup node cannot be found ... " error as I start building more complex commands (like building channel macros).
The only way I have found to "fix" this error is to go back valid configuration - periodically copy your configure folder to  safe place so you do not lose much work.  Deleting whatever I added between when it worked, and when it doesn't work doesn't seem to fix this issue.
Stan
