Hi I just bought the software from eBay, But when I loaded on windows 7 - 64bit I get this software look. am I missing a window software to have work right, thanks
I have installed Comdlg32.ocx and Microsoft .NET version 3.5 framework
Based on the image it is as expected.
Look at the icon to the right of the string: Configuration Tool - Serial No. at the top of the screen. It has a red cross through it, this means you are lacking the driver and so haven't connected to the remote.
Is it not illegal to sell the configuration tool on eBay?
I would say you should report the seller and reclaim your money.
I don't understand why B&O make a software easy free for beo6 or 5, My house is full of B&O products master linked, I use the products from morning to night, but the beo6 remote is the only product I don't use, it sitting there just looks good hoping one day I can take control of it and set it the way I want to. Its should be like an iPad with iTunes.
I am moving to Malta shipping all my stuff over there is no B&O support, That why I bought the CD from ebay, I am a technical person I should be able to finger it out. But it looks it work better on Window XP. I have window 7 - 64bit. I need to try to see why it loading like that. I must have a missing DLL or a missing window driver.
Thanks for your help.
Check to see you have the correct driver loaded - go to Control Panel - Device Manager (in Windows 7). I found that I had the device driver for Beo5 as this came with the Config program. I couldn't find the correct driver so I renamed the existing one changing the 5 in its name to 6. This connected me to the Beo 6, however, I haven't made changes to it yet as I believe this would overwrite the the current configuration on the remote. I haven't the time at the moment to set it up again from scratch.
I also found the wireless connection difficult as Beo 6 works with 802.11g and my router was 802.11n which should had been backwardly compatible with 802.11g but wasn't.
If B&O sold satnavs the way they sold Beo 5/6 remotes you would have to take your satnav to a dealer every time you want to enter a new journey.
Good luck with it all.
