Since the release of the B&O Configuration Tool there appears to have been some confusion related to working on 32 and 64 bit operating systems and versions of firmware loaded in the Beo5/6
Firstly, the configuration tool WILL work on Windows 32 or 64 bit operating systems. NOTE: generally speaking if you buy a 64 bit computer you will also have a 64 bit operating system loaded. However, sometimes a Windows 32 bit operating system is loaded on a 64 bit computer often because of lack of 64 bit USB drivers. So, when checking if you have a 32 or 64 bit system, check the operating system version, not the hardware type. To check the operating system press START then CONTROL PANEL then SYSTEM and it will be displayed.
Below is a small table showing what will and will not work
*1: Will be updated to 3.00a by the configuration tool next time you download a configuration
*2: Will be updated to version 1.45 on the next configuration download
It should also be noted that if you have a Beo6 with a firmware version for driving the USB on a 32 bit system and the firmware is updated to make the USB use 64 bit, then the Beo6 will no longer be able to be connected to a 32 bit system.
