Configuration software update
Hi
Just to let you all know that there is a patch update to the config software taking it to v1.12.  Not had chance to see what's new... but will post back when I have had chance to play.
Greg
Hi
I got this patch some weeks ago, it updates your Beo5 software to 1.20a, and just fix some problems with USB port to recognize your Beo5. I guess we are talking about the same patch.
Regards
From which location should the Beo5CTPatch_1.02-file be opened?
