Config Tool screen is cut
Perhaps I should uninstall/reinstall the software, but then I will loose all my configs. Right?
You will NOT loose your configurations. You configurations are in a file with the Beo5/6 serial number as below:-.
Right. But what about the custom icons I created? They will ne lost unless I copy them in the new folder.
If its any help- mine does and just did on a 64 bit win 10 machine. Pity that its got to be in offline mode
Regards
Ben
Installed the Configuration Tool on a different computer, but had the same problem with the screen. Realized that I used v6.62. Installed v6.84 and the problem was solved. Nevertheless, there seems to be a bug: after a V1 configuration upload, I go to Choose Products, right-click on an apparatus in the Select Zone part, then select Set Source Logical Connections, no windows opens. To circumwent the issue, I first had to remove an apparatus, go to Edit tab, then go back to Choose Products, and do the right-click on an apparatus and select Set Source... then the windows opens.
Very simple...
