Can Beo5 control a Virgin Media STB?
It says Table 1.4 and SW 2.3 on my Avant. The Virgin box is a Samsung V Box.... cheers.
I dont think this box is available on the STB table, even the most up to date table.
You couls always check with your dealer tho, there maybe a new one.
I would not worry about your terrestrial signal, that will be switched off soon enough anyway. Has your place in London got a digital aerial? I know you can pick up most digital channels using a basic analogue aerial, but the digital signal does not suffer from shadowing from buildings like the analogue signal so getting a digital aerial should improve your chances of getting a good digital reception if you go for the DVB-T module.
If you are in a block of flats this might not be so easy tho!
Good luck.
The terrestrial reception is very bad - analog and digital - so flats in the area do not even have an areal.
Suprising in the center on London (old street).
 p.
