Can Beo5 control a Virgin Media STB?
As the topic asks - can it? I have a Virgin media box and a Sony DVD recorder connected to my Avant and ideally would like to control them all via the remote but not sure if the Beo5 supports either...... Anyone with some inside info? Cheers all.
Yes but not directly. You have to use the on board STB control on your television. Bang & Olufsen have just updated the PUC codes again and added more UK cable and sat boxes including the virgin v+ box.
If your television is in the current range you should be able to get your dealer to update the STB list. Needs to be done by your dealer as they will have the software to upload the data file.
I hope this helps.
Sorry just re read your post and you have an Avant. Not sure if a new chip is available for it which carries the new boxes. Again ask your dealer they should know.
Vinnie.
I have the same question regarding the Homechoice (now Tiscali) ADSL/TV box
p.
which box have Virgin given you? and do you know which stb table you have on your avant? you will be able to find out which stb table you have by pressing tv, then menu, then with the menu open press 00 then GO. Then on Monitor information press Go, you should then see your STB version.
I might be able to check if you box is on this list.
wtlc2zpx - do you also have an avant?
Just checked and Homechoice PVR is on the STB list 3.91 version. You should be able to control it with that but may require a new chip.
Check to see what STB control is in your tv.
No, I have a BV7-32... so I think they can update the software with just a laptop.
p.
Yeah that sounds much better. As you say the laptop solution will work, not sure what they charge for the service tho. Would be good to get the apple tv etc and other boxes that might come into use at a later date, PS3 and Sky HD box just in case you switch at any point. Easy for them to add loads of different boxes and only takes minutes to upload the data.
 Vinnie.
Then get them to update your Beo5 if you dont have the software tool.
