Bugs in SW 1.32a ?!
I updated as well and everything looks to work properly. Thanks to Quim as well for the info.
In addition it solves a bug I had with software 1.30a (I did not see any reference about it).
The bug is related to the following: if you configure the Beo5 with a third party accessory like Lutron Rania IR, after using one of the Lutron codes, the Beo5 IR Power range gets reduced, so you need to point directly to the equipment IR receiver. This continues to happen until you power off and on the Beo5, then works properly until you press any of the Lutron commands again. This does not only happen with lutron codes, I think it happens when you use a non B&O IR code.
I'm full controlling now 5 non-B&O devices (Philips, Thomson,
Sony, Panasonic and Pinnacle) directly with the Beo5, and of course
thanks to Keith's XML generator tool and his help info procedure... the beo5 works very well in all
cases 🤒
but here is the difference with the majority of beo5 users: I'm still
using the Beo5ConfigTool 1.02 with Serializer version 0.35, and my Beo5 still has the 1.20a firmware... 😳 and NO bugs however !!! the 3rd party support is also working perfectly well.
Everything works correctly, but I've not upgrade the Beo5 firmware to 1.34a yet, and I'm not using the 1.30 Beo5ConfigTool
ujn2:
That is not enough.
That will not give you the full 1.34a firmware - there are still some things missing.
Aha, what is missing, the remote says 1.34a as firmware release when i look in the service menu, and the 3rd party support is also working?
/Weebyx
I'm not sure, but I did also update my Beo5 like this when the 1.34a was released. However I was missing full support for the Lintronic box - so I could not use the CNTL_X and FUNCTION_X until I did a get update from a "online" Beo5 config tool.
hey guys,
can you give me a little howto how i can get the new firmware files offline?
or do i only have to change the values in the beo5ct.exe?
firmware 1.34 work for me just fine!
but i can´t control my sat receiver. when i´m in the living room, where its connectet with the bv7 it works. but if i go in the celler, where the receiver is, the remote doesn´t work. my other non b&o sat receiver in a other room doesn´t work too.
the only non b&o product that work is the apple remote, but not correctly. what do i wrong? is it possible to get my non b&o devices to work?
