Bugs in SW 1.32a ?!
Does anyone else also have problems with the new SW 1.32a?
The battery of the Beo5 doesn't last very long anymore...
and look at this German thread:
I have the same problem, it's drainning the battery. But I only have software version 1.30a. Are you sure it's 1.32a?
/Frank
The latest firmware update is 1.32a. The firmware is what is loaded into the Beo5.
The Configuration software remains at version 1.30
My Beo5 says: 1.30a, got it last week.
/Frank
Are there solutions for the battery problem?
Or do we have to wait for another update........?!
Hi, the problem should be solved in the SW released today or tommorow, i talked to B&O today, since i found a bug in SW 1.32a. The bug was that if you only changed the volume and then set the remote down, the display would not turn of until you pressed a button other than the volume slider.
 I am having mine upgraded tommorow, so looking forward to that.
/weebyx
firmware version 1.34 has been released.... solving mentioned problems.
Will be downloaded into the Beo5 Config tool when logged in to the Bang & Olufsen retail/dealer site and installed into the Beo5 during serialization.
Is there also a change in the configtool (now 1.30)?
