Bugs in SW 1.32a ?!
You need the Beo5CT.exe.config and the files from the firmware directory. Thats all.
Put the files on your PC (overwrite the existing files) and start the serialization. The new firmware will be loaded.
Did someone ever get their 1.30 tool to update firmware to 1.34a offline ?
/Weebyx
Weebyx:
/Weebyx
A member from Spanish Beoworld did it.
Also got it working, just replaced the 5 files in the firmware lib, and changing the beoconfig.exe.xml file from 1.30a to 1.34a,
/Weebyx
That is not enough.
That will not give you the full 1.34a firmware - there are still some things missing.
You need to edit the Beo5CT.exe.config and change these values:
<add key="Beo5RevE.bin" value="1.34a" />
<add key="Beo5RevF.bin" value="1.34a" />
<add key="Beo5RevD.bin" value="1.34a" />
That will not be enough, you will still be missing some features when using this method.
Weebyx has got his Beo5 updated correctly including the configuration file.
