Bugs in SW 1.32a ?!
Doc,
When I have the newest firmware I will put my results here.
First I have to find it.
Piet
Hello Piet,
never tried this before. Should work in theory.....
groetjes
Jeroen
jeroenv:
firmware version 1.34 has been released.... solving mentioned problems.
Will be downloaded into the Beo5 Config tool when logged in to the Bang & Olufsen retail/dealer site and installed into the Beo5 during serialization.
Well, that's a problem for me. I can't login to the Bang & Olufsen retail/dealer site.
Question: when I copy the files from the 'Bang & Olufsen\Beo5 Configuration Tool\Firmware\' directory from my dealer (after he has download the firmware once) and put the files on my PC. Will that do the job for firmware version 1.34?
Piet
So if I understand correctly, you want to change your current five "1.30 / 1.32" .bin-files from the Firmware-directory , for the "1.34" .bin-files you get from your dealer?
And some other files. Only the bin-files is not enough. I think its possible.
Piet
Doc,
I am busy with it.
Besides the firmware directory I think the Beo5ct.exe.config, both serialize files and maby the Beo5ct.xmlserializers.dll
What would help is a directory listing of the ../Bang & olufsen/Beo5 configuration tool and the firmware directory from someone who has firmware 1.34 installed (with filenames, size and time stamp).
Who has it?????? Sent it to me, please!!
Piet
