Bose XML File
Chris wrote:
Do you have a link to the file? Chris
Chris,
Can you please read my previous wording again..
The link you used last time in my previous posting is the link to use. The file has exactly the same filename as before and is downloaded from the same link.
Apologies Keith, it had been a long day at work!
I am testing the file and it seem to be controlling my Beosound 8 and not the Bose. It's very strange. I could post you the remote if you like?
Thanks again, Chris
Chris,
If you would like to send me your remote I will check it out for you. I will PM you.
Martin, You are a credit to Beoworld! The file works perfectly and is very easy to control on the remote.
