Bose XML File
I remember seeing a while ago an XML file for Bose remote control. All I am wanting is Volume Up/ Down. Mute and possibly On/ Off.
Thanks!
Dear Mr....
Thank you for contacting BOSE®.
Unfortunately we do not have the HEX information for the CineMate systems available, however many universal remotes have a learning facility built in to them and will allow a customer to gain the necessary information from a remote in this way. The only buttons on the CineMate remote you would need to learn will be on/off, volume up, volume down and mute and the rest of the functions are used as part of its universal ability.
Should you have any further questions then please feel free to contact us on 0870 741 4500 or by replying to this email.
Please note that our Aftersales/Technical support opening hours are from 9am until 5pm, Monday to Friday
Kind Regards,
Dan Usher
Technical Support Analyst
Bose Ltd
1 Ambley Green
Gillingham Business Park
Gillingham
Kent
ME8 0NJ
Tel: 0870-741-4500
Fax: 0870-741-4545
Dear Mr Harrison
Thank you for your reply.
I have spoken to the development department to request the required information and have been provided with the following HEX information for the CineMate®:
On Off
0000 006b 0022 0000 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0041 0015 0041 0015 0015 0015 0041 0015 00ac
Mute
0000 006b 0022 0000 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
Volume Down
0000 006b 0000 0022 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
Volume Up
0000 006b 0000 0022 0157 00ac 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0041 0015 0041 0015 0015 0015 0041 0015 0015 0015 0015 0015 0041 0015 0015 0015 0041 0015 0041 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 00ac
I hope this helps.
Kind Regards,
Dan Usher
Bose Ltd
Chris, just bring your Bose remote and Beo6 into the store and I will do it for you, takes about 10 minutes!
Call ahead though to make sure I am in.
Martin (B & O Newcastle)
Martin, I have sent you an email. Unfortunately I live in West Yorkshire however if you could create a file I would be willing to post you my Bose Remote control if you like and send it back to me.
Thanks, Chris
Chris,
I have converted your Pronto HEX codes and made an XML file which is
Hi Keith, Thanks very much for creating this file. Unfortunately it doesn't seem to work. I will get in touch with Bose - maybe they have provided the incorrect HEX codes.
Also another question. I have a Beosound 8 and it will not work with the supported BS8 file on version 4.11 - It does however work with a Radio/ CD function on the Beosound3000 - play, pause, volume up/down etc. Is this a common fault?
Mute: 0x01
Device Code: 186.160 (0xBA.0xA0) Function: 1 (0x01)
0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Volume Down: 0x02
Device Code: 186.160 (0xBA.0xA0) Function: 2 (0x02)
0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Volume Up: 0x03
Device Code: 186.160 (0xBA.0xA0) Function: 3 (0x03)
0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689
Power: 0x4C
Device Code: 186.160 (0xBA.0xA0) Function: 76 (0x4C)
0000 006D 0000 0022 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0689
Hi Keith, Can you have a go at these? Thanks :-D
I have created a new XML file with exactly the same filename at the previous posting link where you downloaded before.
These codes look much more positive and decode to standard NEC 32 bit protocol and are much more likely to be correct.
Do you have a link to the file? Chris
