BeoSystem 2 config files?
My installation of the Beo5 Config Tool is missing configurations for BeoSystem 2 (BeoVision 4) and MX6000 with BeoLink Video. Does anyone know if those should be part of the system or what product I should choose as replacements?
As far as I can tell those products are not even installed with the tool, the folder "c:\Program Files\Bang & Olufsen\Beo5 Configuration Tool\Products\20.Video\20.BeoSystem\" only contains xml files for BeoSystem1 and 3.
Thanks for any advice
/axl
Hello and welcome to Beoworld,
Whilst the actual products you name are not in the standard list does not mean you cannot create a configuration.
For the Beosystem 2 (Beovision 4) I would use the Beosystem 1 US and make the few minor changes manually.
You will also note that under Beovisions there are some generic Beovisions called VIDEO1, VIDEO2 & VIDEO3
For the MX6000 you can use the MX4200
The fact that you have used different configuration XML files in the Tool does not show up once download into the Beo5
