Beosound 5 specs
Wow, it looks very cool in pictures! The price is over the top though, even for B&O! Anyway, I have some questions that somebody in the know will hopefully be able to answer:
1) Are the specs (connections etc., etc.) sufficient to ensure FULL HIFI quality (if ripped in CD quality) - i.e. is it "worthy" to be connected to Beolab 5 speakers?
2) If I'm correct the Beomaster 5 serves as the "brain" and the Beosound 5 as the navigation point. If so, is it possible to connect several Beosound 5s in different rooms to one central Beomaster 5, thereby effectively creating a type of link system with navigation screens in each link room (if not, you would presumably be controlling in the blind in link rooms which obviously makes no sence what so ever!).
3) Can you operate the system via the TV screen (like Beomedia) - this is really necessary since B&O appears to not offer two way remote! If it is indeed possible to operate the system via a TV screen, could you potentially just buy the Beomaster 5 and skip the Beosound 5 and "just" operate the whole thing in a similar way the Beomedia works?
4) Will the Beomaster 5 replace the built-in Beomedia in Beovision 9?
5) When importing music from the PC, is it possible to import play lists? If not, then it's really a deal breaker!
 6) I agree with the complaint that the unit doesn't include a DVD drive (meaning you will need an additional "box" which, by the way, B&O will stop producing according to their new strategy plan!?!) and a radio. You could of course listen to internet radio, but I guess internet radio is often distrubuted in compressed quality (?)and therefore not "worthy" of a HIFI system.......?
The answer is Yes for all your questions...
And for point 6... FM is not CD quality, so a not so compressed N.RADIO can be just as good.
Regarding point 1, if you use the Lossless format, you have the same quality as with a CD. If you send the signal through SPDIF to Beolab 5, then there is no loss at all...
Otherwise the DAC is supposed to be of a very good quality.
(Why can't I edit my own posts, in this Forum).
My Mistake Sorenfelden, regarding point 2... only one Beosound 5 per beomaster 5.
But rumour has it that there will be in the future some modules for link rooms.
Phil, have you got an 'edit tab above your post?
By the way, your user name is much better than your previous one. More friendly.
I do not have the Edit tab in any of the Beosound 5 forum thread!!! Strrrrange....
I have only discovered recently that I could have a display name.
I remember this happening when we started the Beo5 forum. I don't have an edit button either on this forum. I'm sure Keth will sort it soon.
Sorry! My fault! The forum was set up quite quickly and originally was not made so anyone could write to it! I have altered that but don't often play in these areas so missed the Edit button! It is on another page!
Sorted Peter, thanks.🤒
The specs does not seem to tell whether it supports 24bit/196khz playback. So anyone knows whether it does? Anyways so far it doesn't look very exciting. I thought will the new CEO, B&O will march into the whole high end vision and audio territory.
