Beosound 5 Shows Multiple Albums and Artwork for Same Album
Hello,
I am new here and recently purchased the BeoSound/BeoMaster 5. I had my music loaded by the retailer and when it was setup at my home I have noticed that I have multiple albums with multiple artwork for the same album.
Example: Barbra Streisands album called duets shows 20 albums with one song each and not a single one contains all songs. As I am new I am only using beoplayer to view, edit, and add music. Is there a way to correct this using beoplayer? I can see all my music from BeoMaster 5 in beoplayer but not sure how to correct the problem. Any assistance would greatly be appreciated. Oh and I should note that I am not a great techie so easy would be great. Thanks all!!
Welcome to BeoWorld!
This is a common matter of needing to clean up the tags on the music files. You can do with with BeoPlayer, but I find it to be much faster to just delete the songs from the BeoSound 5, edit the tags on those songs using iTunes, and then send the re-tagged songs back to the BeoSound 5 using BeoConnect. Using iTunes, you need to tick the "part of a compilation" box and then make Babs the "album artist." While you're doing this, it's a good idea to delete the cover art and replace it high-res cover art if needed. This will also fix your problem of seeing multiple cover art on various songs within that album. Hopefully you only need to edit the files for albums that have various artists (such as duets).
I've found a great source of cover art to be on this site that provides the cover art used in the iTunes store:
http://iart.toaos.tk/dashboard
Thanks for your reply much appreciated.  However, I have a lot of albums like this and was really wondering how I could correct the issue using beoplayer again not really that proficient in using itunes.  I also have been using beoplayer to add music to my Beomaster 5.  This is all so new to me - and at this point I almost wish I hadn't bought this.  ;-)  Thanks again!!
use  mp3tag (see www.mp3tag.de)
easy and exellent tool to add and modify one file or one album etc. You can download tag info from several sources to adjust or complete to your wishes.
Advice: choose a way how to store files and the way you want the tags to be. Than stick to it. Then it will be coherent in the BS5.
You can certainly use BeoPlayer to edit the music on the BeoSound 5. I did this initially when I bought my BeoSound 5. I just find BeoPlayer to be rather slow and cumbersome. ITunes is much faster and easier for editing, and iTunes give you more control than does BeoPlayer. However, iTunes cannot edit direclty to the BeoSound 5 as BeoPlayer does. It sounds like the upcoming ripping drive might be ideal for you if you're not comfortable with iTunes.
Don't get discouraged. The BeoSound 5 shows all the flaws of incorrect tagging and low resolution cover art. After I got mine, it took me WEEKS to painstakingly re-edit the tags via BeoPlayer and to replace the cover art. Mind you that this was due to my own laziness of years of neglect in properly tagging my music. Now that it's all perfect, I can truly enjoy my BeoSound 5 and appreciate it all the more. I suppose the appreciation can be similar to that of re-waxing one's own Barbour wax coat rather than sending it back to the factory for re-waxing. It makes it more personal.
Once you have the tags corrected, you'll want to make a backup copy. I suggest connecting an exernal hardrive and a mouse and keyboard directly to the BeoMaster 5 to do this. You just go into the service mode on the BeoSound 5, locate the files, and copy them to the external harddrive. You can also have BeoPlayer create a copy on your computer's harddrive.
Hello,
The upgrade is available since yesterday evening, and Solve this problem, (only one album is still problematic for me )
Check it out
Regards
Eric
Thanks for your response much appreciated.  Still not sure which tags to change to make this work - I guess trial and error.  🙂
Eric thanks - do you know what the current new version is?
Carolpa, thanks for your response - much appreciated!  Can you tell me if mp3tag will recognize the Beomaster 5 files/directory so I can make the change on the Beomaster itself?  Any help you can give would be great.
you can access the files on the BM5 directly.
You' re using a PC or a Mac?
