beosound 5 new install
Hi Guys
I have just installed above for a client, 10/3/2010. I have done the update on the head unit, I can switch on the unit by pressing cd, or radio, but when i try to change the track, normally by pressing the cursor button, nothing happens, the same for the radio, I have installed a few, but noramlly in radio mode if I pressed the number keys it go the radio station, i.e press 1 Radio 1. 2 etc but it is not working either, I have switched the unit of and back on again, but still no joy, tried the Beo4 on bv8-40 and it seems to be ok. Is this a software problem?? or Iam I doing something wrong.  Any pointers would be appreciated
Kai
Hello Kai,
did you set the Beosound 5 to "Audiomaster" or is it used as a slave system?
Did you set the "CD" and "Radio" buttons in the settings menu of the BS5?
I noticed similar problems immediately after I had installed my new system.   Impossible to store Favorites, for instance.  Reboot didn't help.
Then, after I had uploaded CD's to the BM5, it all started to work as expected...
Alain
