Hi, I have just now bought a BeoSound 5... no Encore... I would like to know if any of you managed to connect it via WiFi and how, namely with what kind of product... thanks a lot for the advice you can give me!
Bye
Adriano
Bye
Adriano
You’d have to connect a usb wifi dongle - and have the right drivers in the op of the BeoMaster......and go into the BM5 settings menu to enter the password for your wireless network.
There used to be a compatible dongle, but I am not sure if this is available anymore - ask your dealer.
An easier solution would be to get a wireless access point with an ethernet port - and use that for the connection to the BM5.
This might also be perferable because of the better quality of a modern wifi solution.
Alternatively you could use a PowerLine adapter (in a similar way).
Thanks a lot Millemiseen ... the preowner of Beosound 5 suggested to me to buy a Power Link Adapter by TP-Link ... :-)
I am sure, he meant PowerLine adapter - as also suggested above.
